            anees
                Posts58
Everything posted by anees
	hello i want to use attach inverter and battery as off grid can you please add that on database ? thanks @developer_bh @developer_fa @developer_jh FICHA TECNICA ION 2ND GEN 5kw-12kw.pdf bateria ion tipo rack.pdf
	can you please add solar modules that i attach? Solar Hero Pro2 HJT.pdf
	Hello can we configure pvsol such then solar should charge battery first and when power from solar is high then 1) it should charge battery first 2) if power is extra then that power cover load 3) if still power is left then that should goes to utility
	my battery is charging from utility please check my charging strategy @developer_fw i will send you pvsol file in your inbox
	hello i am using sma battery that charge from utility and i want it to charge from solar how i can do setting i want battery to help me to offset peak load what size is good i can not attach pvsol due to server issue of website i can not see charging strategy on pvsol that can help me to do it
	@developer_mh where is charging strategy option onpvsol ?
	@developer_mh here it is
	@developer_fw any update on modules on database?
	PV generator output 9.43 kWp Specific annual yield 695.83 kWh/kWp Plant utilization ratio (PR) 74.64 % Yield reduction due to shading 5.5%/year PV generator energy (AC grid) with battery 6.346 kWh/year under yield it says annual yield is 6,346 kWh per year and not 9.43*695.83=6561.67 why?
	can you please add 410w from this datasheet thanks jolywood-410w-bifacial-glas-glas-black-datenblatt.pdf
	@developer_fw how much time it will take ?
	hello i want to use 3 battery of byd but there is no byd in database can pvsol team add this for me ? i can to use this 3 x BYD HVM 22.1 i also attach file of project and datasheet 1.pvprj 2.-BYD-BATTERY-BOX-PREMIUM-HVM.pdf
	how i can check my pvsol license expire date
	hello i want to fix shadiing losses in 2022 r6 premium how i can?
	@developer_mh you are amazing big thanks man
	@developer_mh please check either i have right concepts or nor i want to feedin extra energy (at 0.045) to grid ( no limit ) and i did it in rate 1.PNG attachment is that okay? is it nessary to use the same in fianacical analysis page ( this is also attach) to make it easy for understanding please check my COMBINE ATTACHMENT.PNG please Thanks for your help
