anees
anees's Achievements
Enthusiast
Enthusiast (6/14)
  1. hello i want to use attach inverter and battery as off grid can you please add that on database ? thanks @developer_bh @developer_fa @developer_jh FICHA TECNICA ION 2ND GEN 5kw-12kw.pdf bateria ion tipo rack.pdf
  2. can you please add solar modules that i attach? Solar Hero Pro2 HJT.pdf
  3. Hello can we configure pvsol such then solar should charge battery first and when power from solar is high then 1) it should charge battery first 2) if power is extra then that power cover load 3) if still power is left then that should goes to utility
  4. my battery is charging from utility please check my charging strategy @developer_fw i will send you pvsol file in your inbox
  5. hello i am using sma battery that charge from utility and i want it to charge from solar how i can do setting i want battery to help me to offset peak load what size is good i can not attach pvsol due to server issue of website i can not see charging strategy on pvsol that can help me to do it
  6. @developer_mh where is charging strategy option onpvsol ?
  7. hello i want to check my inverter input power as accurate as i can from pvsol so i simulate it with one mintue interver QUESTION this one mintue interval shows average value of its sum of one mintue ? @developer_cd @developer_rh
  8. Hello Hope that you all are good and thanks for helping me everytime here i want to want to know what is best model for irradiation on inclined plan ? Perez?? 2) what is best model for diffuse irradiation?? Project locations are UK and Germany Thanks
  9. @developer_mh here it is
  10. i think 3502*0.4= first year saving
  11. why these 2 values are differnt ? test (1).pdf
  12. @developer_fw any update on modules on database?
  13. PV generator output 9.43 kWp Specific annual yield 695.83 kWh/kWp Plant utilization ratio (PR) 74.64 % Yield reduction due to shading 5.5%/year PV generator energy (AC grid) with battery 6.346 kWh/year under yield it says annual yield is 6,346 kWh per year and not 9.43*695.83=6561.67 why?
  14. can you please add 410w from this datasheet thanks jolywood-410w-bifacial-glas-glas-black-datenblatt.pdf
