Hello Martin,
Thanks for the reply.
I am using the software Agisoft PhotoScan for photogrammetry. I was able to rotate the 3D model and successfully transfer it to PV*SOL. Thank you very much!
Regarding the model size, I will try to keep it small, thanks for the tip!
Best regards,
Alvin
Hello Martin,
I tried resizing the window manually, but the cable section just vanishes completly (see figure). The best result that I got was pushing the windows toolbar to the right (see figure). Ideally it would be nice if I could resize the section where it says "Resumo de todos os cabos".
Thank you.
Greetins.
I am working on transferring 3d models from Google Earth Pro to PV*SOL using a photogrammetry software. I am able to export the .obj file and place it in the 3d ambient of PV*SOL, but the model seems to have some unusual coordinates and appears to be tilted compared to the surface of the 3d ambient. I tried tilting the model but it didn't help much. I would like to know how can I solve this problem and have the model and the 3d ambient parallel to each other. I am attaching some images of the issue.
Thanks.
Hello everyone.
I have a problem with the cable menu on my PV*SOL Premium 2019. The menu beneath the project schematic is way too small and dificult to read and make ajustments (I am putting a image as reference). I would like to know how can I increase the size of this menu for a better visualization.
Also I've noticed that you can add a "Max. Power Loss" in this menu as well, and I would like to know how to do so.
Best regards.
