Ola Andersson
Everything posted by Ola Andersson
  1. Hi Will you also fix the problem that has been there for a long time, that is: You have entered 3D extrusions on an Open Area and discover that the orientation needs to be adjusted. And when you adjust it, that is change the orientation, you have to redo everything as the objects don't turn in the same way as the Open Area?
  2. Hi When using an own bitmap you have taking away the option to set the orientation on the Open Area - why? And when setting the orientation in the first user interface it is not logical. 180 degrees: upside down. 15 degree -15 azimut. 90 degrees: azimut 90. It is now pretty much unusable. Before: When you turned the Open Area, why didn't the objects on it turn the same way. Instead some turn, some not, so you have to start over again. Still better than it is now though....
  3. Hi I think the best way is to use the drawing as a Map. Then you can use that as the basis for clicking in the right spots with the polygon tool. Just be sure to put the drawing - the "Open Area" in the right azimut direction first. These features would be very helpful: - Polygon tool that makes right angles while drawing. - Possibility to enter exact coordinates with the polygon tool. - Fix the bug that the objects on the Open Area get disorganized when changing the Open Area direction (prio!) - It should be able to have the texture applied all the way upwards, also to arbitrarybuildings and objects. Best regards, Ola
