Sander
Sander last won the day on February 14 2022
Sander had the most liked content!
Contact Methods
  • Website URL
    www.segco.be
Profile Information
  • Location
    Belgium
Sander's Achievements
  1. Dear, The VW ID cars show V2H behavior in the calculations. The car is being discharged for inhouse consumption. Is this a bug and/or is there a way to switch this off? Best regards, Sander
  2. Sander
    PV*SOL Wishlist
    I would like to see the option to select "electric heated boiler" in thermal systems tab. Most boiler systems in Belgium are electrically "heated" during the night using a economic rate) Now i can only select gas/wood or oil, which looks off in the presentation.
  3. Hello, Is there a way to calculate the payback time of a project when installing a retrofit battery? (So there is already a PV-system in place, but the customer wants to add a battery.) The payback should be based upon the increased lvl self-consumption and the cost of the battery expansion. Best regards, Sander
  4. Sander
    PV*SOL Wishlist
    - would like to see an undo button as discribed above. (or at least be able to lock a complex building and their surroundings, so one misclick doens't destroy your work) - need more options for EV. (e.g. distance travelled per week day, range according new WLTP system) - while the software perfectly suits my technical needs, it seems lackluster/old as a client proposal. - could we have a blanc page in the customer presentation where we can add project or installer specific additional information. - some presentation pages need additional (customizable) information. (while a graph or scheme or just some numbers wth a title above will be very clear for us, a customer most of the time doens't know what he is looking at) - file size of the presentation should be smaller, but pictures should still be high res. - would like to be able to send an electronic presentation to a customer with some analytics possibilities. (where do customers actualy look at?) - easier construction of "complex" buildings. (depth of building schould be addapted to the angle and dimensions of the roof area being used for the array)
  5. Agreed Martin, but thats just the AC loss for one inverter, with the included 25m cable lenght. (Your formula should however use the double lenght if i'm correct.) In this case we have 8 parallel microinverters. The biggest problem however is that we already have loss on the AC coupling cable between the inverters we will have to take into account, when sizing the AC kabel. (I noticed I should use 0m lenght for the DC kabel, following the instructions in PV*Sol which i will do next time)
  6. Sander
    Huawei optimizers
    Thanks for the quick respons Martin!
  7. Hi, Included you will find my test project. Sander Enphase test.pvprj
  8. Hi, Is it possible to include the Huawei smart PV optimizers into the next update? Should they work the same as the Solaredge optimizers? Can I therefore include them myself? Thanks! SUN2000P.pdf
  9. Hi, I'm currently looking into a simulation with microinverters. Not having used them before I was interested in calculating the cable losses. I expected high losses on the AC side. (from counter(meter) to microinverters) With cable lenghts easily exceeding the 25+ meter mark, the losses are extremely low. The DC losses however seem to be too high. Am I missing something or are the calculations switched? * using the cable tab to caculate the losses in detail Best regards, Sander
