How to use one inverter with two side of the roof
Hello, I have encountered when using module configuration, I cannot use only 1 inverter for two different side of the roof. I want to maximize the use of the 2 MPPT's of the inverter. Is there a way to do this??
  • Ken changed the title to How to use one inverter with two side of the roof
Hey Ken,
Yes, you can select the unconnected module areas in the connection dialogue and click on "Connect together" at the top left. The search will then make suggestions that should be valid for your case.
Best regards,
Ben
