hotline_sf Posted May 2, 2019 Report Posted May 2, 2019 I have GeoT*SOL 2019 and PV*SOL or PV*SOL premium 2019. When I start PV*SOL, my climate data set created in GeoT*SOL is deleted and is then no longer available in GeoT*SOL. What can I do?
0 hotline_sf Posted May 2, 2019 Author Report Posted May 2, 2019 GeoT*SOL 2019 and PV*SOL/PV*SOL premium 2019 currently use different versions of the climate data tool MeteoSyn. If a climate data set is created in GeoT*SOL 2019, it is assigned an older version number. When PV*SOL is started, the climate data set created is then determined to be incorrect and deleted immediately, even though it is actually OK. What can be done? If you are using both GeoT*SOL 2019 and PV*SOL/PV*SOL premium 2019 on your PC, it is best to create new climate data sets in one of the PV*SOL programs. They will then be assigned the current version number and will not be deleted. Since all programs use the same directories for the self-created climate data, you can also find the newly created climate data set in GeoT*SOL 2019 and use it there. We will solve the problem with the next update of GeoT*SOL 2019.
Question
hotline_sf
1 answer to this question
