Hi,
I would like to know if I set the p-value to either P75 and P90, can I also download the yield result of the P75 and P90 value? So far I saw the p50 value result even I set it to either p75 or p90.
I really need an answer for this since the bank requires the yield result of p90.
Thank you.
Hi klb,
thanks for your report.
Yes, this is possible. By right clicking on the table, you can copy the data to the clipboard.
Unfortunately I couldn't reproduce the behavior you described. I tested it with our sample project 'Solar Park Neuhardenberg'. If it persists, I think the easiest way to find the cause is to contact our support by phone. Please keep your customer number ready. You can find the contact data here: https://valentin-software.com/en/support/technical-support/
Kind regards
Mikio
