Wen Posted September 2, 2024 Report Posted September 2, 2024 Hi, I'm trying to simulation an off-grid project which has 1315KWh annual constant load, 1.42kWp PV generator output and 5 batteries each has capacity at 100Ah. The days of autonomy of the batteries should be over 5 days. It's proposed to be an off-grid DC coupled system, as PV*SOL cannot simulate it at present so I chosed inverters for it in the software but with no meaning. The configuration of the system are showed below: When I tried to calculate and get the result something showed as follow: I've checked that the energy generated per year can cover the power consumption (about 2000 KWh>1315 KWh), how can I get the result of simulation? Thanks a lot Wen running 1.pvprj Quote
developer_mo Posted September 3, 2024 Report Posted September 3, 2024 Hi Wen, thanks for your question and welcome to the forum community. There are probably times when the battery is not full enough to cover consumption. I would recommend working with either load shedding or a backup generator. Does that help? Kind regards Mikio Quote
