Brendon Posted May 20, 2024 Report Posted May 20, 2024 Quote  Good afternoon, I'm having an issue with a project that I've been designing. It is an 806kW project. I initially designed it with Q-Cell Q.PEAK DUO M-G11S+ 415W Rev1 which is on their database. I've redone the design with Q Cell 440W, which I've inputted on the database myself, and the overall annual production has reduced significantly even though the kWp is the same. I've interrogated the PV system energy details, and it appears the cause is the parameter titled - Reflection on the Module Interface. On the original design it was 0kwh/m2, but with the new panel, it's increased to -71kWh/m2. My question is, is there anything I can change on the module database that can reduce this figure to zero? I've tried to change certain aspects, but to no avail. Any assistance would be greatly appreciated. Quote
developer_mo Posted May 28, 2024 Report Posted May 28, 2024 Hi Brendon, thanks for your post. It's difficult to find out the cause without the project. But you can post the project here or send it to me via personal message in this forum so that I can take a look at it. Kind regards Mikio Quote
