Audrius Posted April 25, 2024 Report Posted April 25, 2024 Hello, Â I'm making shading tests with PVSOL and trying to investigate how different shadings on different module cells reduces module and whole string parameters. I'm using Swiss Solar IBEX 144MHC-COSMOS 450 Wp modules. According to the literature half-cut modules with 3 bypass diodes celss are divided in to the 6 equal string. I tried to model these cases (3-7): And I got PV curves, which shows 3 cell strings: Please specify how PVSOL program is design. Does half-cut modules cells are divided in to the 6 cell string or 3 cell string like standart modules with full cells? Â Â Â Quote
developer_mo Posted May 13, 2024 Report Posted May 13, 2024 Hi Audrius, thanks for your question. Half-cell modules are divided into 6 cell areas and considered accordingly in the PV*SOL shading loss calculation. Here is a post by Martin on this topic: Does that answer your question? Kind regards Mikio  Quote
