January 17, 20242 yr comment_15000 Hi, How can I display the characteristic curves for a grid-connected project? When I select characteristics curves in the diagram editor, I obtain the message: "No characteristic curves available. Please activate recording of characteristic curves in Program Options". I have selected: "Record characteristic curves for modules/All" in Options/Project Options/Simulations. However, I still cannot see the characteristic curves. Is there anything else I must do to obtain the characteristic curves? Thank you. Report
January 18, 20242 yr comment_15007 Hi Felix Galan, thanks for your report. Your configuration sounds right to me. A colleague from our hotline told me, that this could happen if the number of MPP Trackers are higher than 20 but I wasn't able to reproduce this behavior. Is your project quit big? Kind regards Mikio Report
January 18, 20242 yr comment_15009 Hello, I have the same problem. When modules are unshaded, curves are not drawn. When I place objects that cast a shadow the curves are drawn. In my configuration, there is a 6 kW inverter with two strings of 12 modules on MMPT. Report
January 23, 20242 yr comment_15046 Hello Audrius, hello Felix Galan, again thanks for your report. We could reproduce it and it will be fixed with the PV*SOL Premium 2024 R4 release. Kind regards Mikio Report
