Marcelschil Posted January 9, 2024 Report Posted January 9, 2024 Dear Team, is it possible to change the Excel Format when exporting the hourly values from the Project? The problem is that the Data-format of the time (date plus hourly values) is incapable of forming a Pivot tabelle. Quote
developer_mo Posted January 9, 2024 Report Posted January 9, 2024 Hi Marcelschil, thank you for your post. Unfortunately you can't specify the column format for the export in PV*SOL. But there are several ways to split the first column into a date column and a time column. One way would be to use Excels "Text to Column" feature where you could specify "Space" as delimiter. Therefore you have to add an additional column after the first Date-and-Time column. Then select the Date-and-Time column and head to the "Data" tab where you find the "Text to Column" button which opens a wizard where you can specify the delimiter to "Space" (in the second step of the wizard). Please find a detailed description and a corresponding video on this Microsoft support page: https://support.microsoft.com/en-us/office/split-text-into-different-columns-with-the-convert-text-to-columns-wizard-30b14928-5550-41f5-97ca-7a3e9c363ed7 Hope this helps. Kind regards Mikio Quote
