obikerui Posted December 12, 2023 Report Posted December 12, 2023 Hello, I'm new to PV Sol and have created my first project which involves an electric vehicle. I've designed a system with 20 PV Panels, an Inverter and a Battery system. When I generate the report the Production Forecast says the 'charge of electric vehicle' is 0 Kwh/Year (please see attached file). It doesn't seem to matter which parameters I alter I can't affect this value. I've added consumption, electric vehicle type, range, charge times etc but nothing has an effect. I'm starting to wonder if I've encountered a bug with the software as the Calculation/Results button skips to the report whenever I press it too. Can you tell how I can affect the charge of electric vehicle value and if skipping the Calculation/Results button is expected in a project with an electric vehicle option? Thanks. Quote
developer_mo Posted December 13, 2023 Report Posted December 13, 2023 Hi obikerui, thank you for your post. There can be various reasons why the vehicle is not charging. It is difficult to determine the reason for your project from the results. Could you share the project file or send me a private message in this forum? Kind regards, Mikio Quote
obikerui Posted December 14, 2023 Author Report Posted December 14, 2023 Thanks for your reply, I've sent you a message and attached the project file. Let me know if any problems accessing it. Quote
developer_mo Posted December 14, 2023 Report Posted December 14, 2023 Hi obikerui, thanks a lot. I received your message with the project file and was able to reproduce the both behaviors (vehicle not charging and skipping result page). We will fix this as soon as possible. I will inform you about the next release under this tread. Kind regards Mikio Quote
developer_mo Posted December 14, 2023 Report Posted December 14, 2023 Hi again, the next release (PV*Sol Premium R3) that fixes this issue will be released next week. Presumably on December 19th 2023. Kind regards Mikio Quote
obikerui Posted December 15, 2023 Author Report Posted December 15, 2023 Hi Mikio, okay thanks for the update. Will look out for the update. Quote
