How to control the Charge of Electric Vehicle values?
Hello,
I'm new to PV Sol and have created my first project which involves an electric vehicle. I've designed a system with 20 PV Panels, an Inverter and a Battery system. When I generate the report the Production Forecast says the 'charge of electric vehicle' is 0 Kwh/Year (please see attached file). It doesn't seem to matter which parameters I alter I can't affect this value. I've added consumption, electric vehicle type, range, charge times etc but nothing has an effect. I'm starting to wonder if I've encountered a bug with the software as the Calculation/Results button skips to the report whenever I press it too.
Can you tell how I can affect the charge of electric vehicle value and if skipping the Calculation/Results button is expected in a project with an electric vehicle option?
Thanks.
Hi obikerui,
thank you for your post.
There can be various reasons why the vehicle is not charging. It is difficult to determine the reason for your project from the results. Could you share the project file or send me a private message in this forum?
Mikio
Hi obikerui,
thanks a lot. I received your message with the project file and was able to reproduce the both behaviors (vehicle not charging and skipping result page).
We will fix this as soon as possible. I will inform you about the next release under this tread.
Kind regards
Mikio
