Dear Valentin Team,
I would like to simulate one off-grid system which a have both PV inverter (in this case Fronius) and MPPT Battery Charger. Respectively their configuration will be AC coupling for the fronius and DC coupling for the MPPT Charger. Finally I will have a Victron Multiplus as Battery Inverter.
Do you know if is possible to simulate this all?
Are MPPT Battery Charger from Victron already included in the database?
Thanks and best regards
Hi Amedeo,
thank you for the question. Unfortunately it is not possible to build a off-grid system with a DC coupled battery in PV*SOL. Battery Chargers from Victron are not included in our database.
However, if you can send us a sketch or a circuit diagram of your system, I can ask a colleague if there is an alternative way to implement it in PV*SOL.
Kind regards
Mikio
