November 7, 20233 yr comment_14505 Hi, Does PVSOL incorporate extra irradiance that the building gets when its closer to the sea? If not is there a way to add this in PVSOL? Location : Vallavikvegen, 1122 Vallavik Report
November 8, 20233 yr comment_14517 Hi hom, in the „Option/Project Options“ dialog is an opportunity to specify a yearly or monthly ground reflection value. Some standard values (for Sea it is 3-8 %) are provided in this table. Does this help with the implementation of your project? Kind regards Mikio Report
November 8, 20233 yr Author comment_14518 default value we put is 20% so now for this place do you suggest to add extra 3-8% ? Report
November 8, 20233 yr comment_14519 Hi hom, no, in this case I would rather suggest to keep the 20 % or even subtract 3-8 % from the 20 %. If the PV system is very close to the sea there is probably less than 20 % reflection from the ground. The sea reflection part probably reduces the total reflection (if it was an floating PV system, the total reflection would be around 3-8 %). I have to add that this is only theory and I don't have experiences how big the impact relay is. Hope this helps to evaluate the configuration. Kind regards Mikio Report
November 14, 20233 yr comment_14566 Hi hom, I have to correct my last answer. Fortunately, a colleague informed me of this. The table should not be interpreted in such a way that values can be subtracted or added. The correct value for your project is 3-8 % albedo because this is the value for seaside installations. I'm sorry for the incorrect information. Kind regards Mikio Report
