Amir Posted November 2, 2023 Report Posted November 2, 2023 Greetings, dear team! Regarding the surface usage factor within the software, can we say that this factor is the same as the ground coverage ratio (GCR)? Because their concept seems to be the same. Regards Quote
developer_mo Posted November 8, 2023 Report Posted November 8, 2023 Hi Amir, It depends on the definition but I think it can be seen as the same. In our online help (in the section Tracking types) we defined the surface usage factor as following: Quote The Surface Usage Factor indicates the distance between the tracked module rows. A surface usage factor of 1 means that the distance from one module row to the next is equal to the width or height of the module. If the surface usage factor is 0, the next row of modules is infinitely far away. A surface usage factor of 0.5 means that the distance is two module lengths or widths. Please let me also refer to an earlier post with a simple visualisation and calculation description of the Surface Usage Factor by Martin. Hope that helps to clarify your question. Kind regards Mikio Quote
