October 23, 20233 yr comment_14421 Hi there, I have been trying to add a battery that is not currently on the data base. I am however not 100% sure if I have entered the battery specs properly specifically in the Capacity Characteristic section. I notice that when selecting a battery system in a PVSol project, Usable Battery Energy is shown at C10. I also noticed that the Ah rating from the battery spec sheets are inserted into the C10 input of the Capacity Characteristic section in the battery database. I would just like to know what the reason is behind this. The battery that I am trying to add is a Freedom Won Lite Commercial HV LifePO4 200/160 - https://www.freedomwon.co.za/wp-content/uploads/Freedom-Won-Spec-sheet_LiTE-Commercial-200_160-HV-1.pdf Is there any chance you could add this battery to the database? Ive added this image from PVSol help, this is the Capacity Characteristic section I am reffering to: Report
November 9, 20232 yr comment_14529 Hello Alex Muller, thank you for your post and sorry for the late reply. I have forwarded your request to our database team and the battery should be included in one of the next database updates. Quote I notice that when selecting a battery system in a PVSol project, Usable Battery Energy is shown at C10. I also noticed that the Ah rating from the battery spec sheets are inserted into the C10 input of the Capacity Characteristic section in the battery database. I would just like to know what the reason is behind this. As the capacity of a battery is not fixed but varies depending on the charging or discharging current, C10 is used as a value to enable comparability with other batteries. C10 is the capacity that the battery has when it is fully discharged with a constant current over 10 hours. It has become established as a characteristic value in the PV industry. Hope that helps. Kind regards Mikio Report
