adamski234 Posted September 19, 2023 Report Posted September 19, 2023 I have a fairly simple PV setup that I'm trying to connect to inverters: After picking the inverter that I want to use I let PV*Sol work out how to connect the panels. However, its results are not satisfactory: This is an ~800 kWp system using 110 kW inverters. It shouldn't take more than 8 of them. And definitely not 15, There are no suggestions with fewer inverters, others use 16 or 17, How do I get the software to use the inverters more efficiently? Nothing in the settings seems to be related or have any effect. Quote
adamski234 Posted September 19, 2023 Author Report Posted September 19, 2023 As it turns out I misunderstood the inverter selection screen: you need to select a checkbox, just pressing on the device that you want and proceeding isn't enough. 1 Quote
