August 26, 20233 yr comment_14164 Hi I have a setup with 4 inverters, and the feed-in to the main panel must be max 200A in total. The inverters are all same model and size, and each at 70A. So the total are 280A How do we set this up correct in PV sol? Thanks, Report
September 3, 20233 yr comment_14179 you have to recalculate the 200A to kW limit =138kW and check the grid limit box ( not the inverter limit box ) Report
