Kevin Posted September 17, 2017 Report Posted September 17, 2017 Can you provide a date for battery storage simulation update? Quote
Kevin Posted September 17, 2017 Author Report Posted September 17, 2017 Is it possible to extend beyond the 5000 PV cell limit simulation? Quote
hotline_tm Posted September 20, 2017 Report Posted September 20, 2017 Hi Kevin, the limitation to 5000 modules within the 3D visualization is due to due to performance reasons. Unfortunately, there is no way to increase the number of modules. In order to plan a pv plant with more than 5,000 modules, you have to switch to 2D planning, where you are able to define an arbitrary number of module areas with 100,000 modules each. Another option would be to divide your plant into supplants and to simulate separately. The next database update, including the battery systems, will take place in early November. Which battery system you miss in the database? Kind regards Your Technical Support Quote
Holbert Posted October 13, 2017 Report Posted October 13, 2017 Great to hear that the new update is planned for early November. Quote
