hotline_sf Posted October 29, 2014 Report Posted October 29, 2014 At the program start of T*SOL the message "Error in installed drives" appears. I'm unable to select any compnonent from the database. What can i do?
0 hotline_tm Posted October 29, 2014 Report Posted October 29, 2014 It could be that the program has a problem to read the TSOL Pro.ini or TSOL Expert.ini file properly.  Please try the following steps: Close the program Delete the *.ini file Depending on your operating system you will find the TSOL Pro.ini or TSOL Expert.ini in the following folder: Windows XP: C:\documents and settings\<USER>\personal folder\Valentin EnergieSoftware\TSOL... Windows Vista / Windows 7Windows 8: C:\Users\<USER>\Documents\Valentin EnergieSoftware\TSOL... Restart the program. It initializes new and creates a new *.ini file
Question
hotline_sf
1 answer to this question
