Enphase IQ-7A-72-2 with SPR P3 385Wp panel not accepted in PV Sol, i know why....
Hello,
I Have checked compatibility** from Enphase IQ-7A-72-2 with *SPR P3 385Wp panel. It says it is possible till 15A max. (Panels* are 10,63A Rated Current*** (Impp) & 11,3A Short-Circuit Current (Isc) (+/−3%).
**https://www4.enphase.com/nl-nl/compatibiliteit-micros#results
But in PV Sol after 10,2A it refuse to accept this combination.
I know why this happen. Because the small letters from enphase datasheet: ""3. Maximum continuous input DC current is 10.2A.""
Strange that Sunpower sells this combination with garranty.... how? And i cannot select this combination after copy this inverter and adjust limit settings in PV Sol from ***10,2A to 11A. First i thougt it was a fault in PV Sol. But now i see it is because the Enphase specs. I will contact them. Now PV sol will not suggests the Enphase micro inverter.
Just someting to share. Where sometimes it gets stuck in work preparation.
Regards, Martijn (OTG.energy)
  • Thanks 2
