Venco Gary Posted May 6, 2022 Report Posted May 6, 2022 The layout were finished but IÂ can no longer access the Results page. I have configured the inverter and no errors have been reported. Could you help me to check with that. Thank you. PV MYZ 4MW -220506.pvprj Quote
Jimmy Posted May 6, 2022 Report Posted May 6, 2022 Hi Venco, You've configured it wrong.   Building 01 and 02 west and building 01 and 02 east have some modules on the wrong building. 1 Quote
Jimmy Posted May 7, 2022 Report Posted May 7, 2022 It's easy to get something wrong and not notice when you have this many roof areas and inverters. I usually rename my buildings to make it easier to keep them apart.  As a side note: Have you thought about using a central inverter for projects of this size? It should keep the cost down by quite a lot compare to over a dozen SUN2000-196KTL. Huawei doesn't have any bigger (except the 215KTL which is basically the same) but there are plenty of other brands that have inverters that are capable of handling all of these panels on a single central inverter. Might be worth exploring if you haven't already done so. 1 Quote
