Rune Strand Sæterøy Posted January 17, 2022 Report Posted January 17, 2022 Hi  I've been trying to add my own load profiles (consumption data) into PV*SOL, but I keep getting this error box saying: "Conversion error in the data line: 1." What could this mean? The file I've been trying to add is a CSV-file and the only data in the file is the consumption, in kWh. Time interval is 60 min, leading to 365 days and 8760 values. The CSV-file contains 8760 values in one column. Thankful for any help! Best regards, Rune Quote
Rune Strand Sæterøy Posted January 17, 2022 Author Report Posted January 17, 2022 Hi again  I tried copying the data into another spreadsheet and saved it as an CSV-file (just like the previous one) and this time it worked. Confusing, but very happy with the outcome...  Best regards, Rune Quote
Jimmy Posted January 17, 2022 Report Posted January 17, 2022 Hi Rune, This is usually for one of the following reasons: * You have a title in your columns on A1, remove that if that's the case. * You have the wrong "numer format file" selected. Basically if you have a dot (.) or a comma (,) as a separator, change that to the appropriate. Â If this doesn't fix it I'll be glad to have a quick look and you can send me the CSV file in a personal message. Â Best regards Jimmy 1 Quote
