Sondre207 Posted November 2, 2021 Report Posted November 2, 2021 Hello, I have added solar tiles to a sketched mounting surface. They are the colour black, and will be surrounded by tiles or different materials. Is there any way I could change the texture of the surface to something different so it would look more esthetical nice? (see image) Thanks for all the help Quote
Jimmy Posted November 2, 2021 Report Posted November 2, 2021 Hi Sondre, If I understand correctly you've imported a model that you've done in Sketch-Up or similar and want to change the texture. Unfortunately it's not possible to change the texture of imported models. You'd need to add the textures to the model in the original program that you made it in. If you do this make sure to not make the texture size bigger than 1024x1024 (although you can use as many textures as you wish) and only use a-z and 0-9 when naming the model or the textures won't load properly. 1 Quote
