October 13, 20215 yr comment_6123 Hi, Is there any way that I can get the string number to match the red line below? When I choose different sorting options, it seems like it is not possible? Could I choose them manually for example? Thanks in advance! Report
October 13, 20215 yr comment_6124 Hi Sondre. Yes. When you're in the "module configuration" view you're actually able to drag panels around. All panels are automatically numbered when you do the inverter config and they'll keep their number no matter where you move them. And the string go in order of panel number. Here's a screenshot of your desired result. An alternative method is in "cable plan" where you can use the "Sketch module cables" tool. Just select the tool and start at the first panel and draw the string going over each module in order. I prefer to move the panels in the module configuration view but I think both are equally valid. Report
