Jimmy Posted October 5, 2021 Report Posted October 5, 2021 I have an imported model of 6 buildings that I'm designing an installation for and I've used the automatic function to determine mounting surfaces, which I don't usually do. It's worked good on the first 4 buildings but when I got to the fifth I noticed that the mounting surface isn't what I want.   I don't want to try to re-determine the mounting surfaces in case that buggs something else. Or should I just try to draw a new surface on the roof? Quote
Jimmy Posted October 5, 2021 Author Report Posted October 5, 2021 So.... I just tried to draw a new mounting surface on the building instead and that resulted in PV*SOL deleting all the mounting surfaces (I was promted first) and removing all the 600+ panels that I had already placed... Quote
Wouter Posted October 6, 2021 Report Posted October 6, 2021 Very annoying indeed. Sometimes 90% of the automatically determined mounting surfaces are ok, only 1 is not, but you have to manually redraw them all if you still need that 1 surface as well. Quote
