Alexandre PARA Posted Monday at 12:07 PM Report Posted Monday at 12:07 PM Hello, I am working with the A13 – Buffer tank system with process heating configuration in T*SOL. I would like to know if it is possible to vary the buffer tank temperature and the process supply/return temperatures depending on the season within a single annual simulation. Specifically: In winter: buffer tank at 60°C, supply 45°C, return 35°C In summer: buffer tank at 90°C, supply 90°C, return 70°C Is there a way to define seasonal temperature settings (for example using time profiles or control functions), or is creating separate variants the only recommended approach? Thank you for your help. Quote
