Gigmolike
Everything posted by Gigmolike
  1. I was able to get the correct roof on the second part of the sketch right away — the program recognized it properly. However, on the part we are discussing here, it still does not work. No matter what I try, I only get a flat roof. I am attaching the whole project and some screenshots. If possible, could you please tell me where exactly I should mark it and how to set it correctly? Thank you very much for the quick response, I really appreciate it.
  2. Hello, I am working on a project in PVsol Premium where I need to model two buildings connected in an L-shape. I have a base plan imported from AutoCAD, and I manually draw the roof outlines on top of it using the drawing tool (pencil). However, PVsol always assigns a flat roof to my drawn shapes, regardless of how I draw them. I tried selecting the outline first and then adding a polygon edge (as suggested in some guides) to help PVsol recognize it as a pitched/multi-slope roof, but it still results in a flat roof. My main issues are: How can I draw two separate buildings and connect them so they appear as one L-shaped structure with a continuous pitched roof? How can I make PVsol recognize my hand-drawn roof outline as a pitched roof (gable or hip) instead of always defaulting to a flat roof? I have attached images showing: The roof type I want to achieve (two buildings connected in L-shape with a continuous pitched/tiled roof and solar panels placed on it) What I currently get (two separate buildings with flat roofs that do not connect properly, with a visible wall gap at the junction) I am importing the site plan from AutoCAD as a background reference and drawing the building footprints manually on top of it. I have also included image links below to better illustrate the issue and the desired result: This is what I got - current result in PVsol: This is what I tried to draw manually - my attempt: This is what I need - the desired result (these two images show exactly what I am trying to achieve): Any help or step-by-step guidance would be greatly appreciated. Thank you!
