Nimesh
14 -
Everything posted by Nimesh
Can I edit this value? and can type desire value if yes how'?
Hello, Here I want to change energy from grid ...... kwh/year. is it possible in pvsol and how? here, I created 2 model one with 2 mppt and one with 1 mppt and all other things are same only inverter version is different and the value of energy from grid is diffrent in both model why? And Where can I find CAPEX value of any system? Gruß, Nimesh
Dear Sir No It is not working. I marked one thing in my pvsol that it is giving I_V curves only in shading files as I create shading it start giving I_V Curves and as I delet that shading it again stop giving curves., 2) Second Question, I am trying to find I(Current) DC and V (Voltage) DC in Excel sheet but I am not finiding, If you could guide where can I find DC- Current and Voltage before converting it into AC, a Clear DC Currernt and Voltage which are coming directly from panels in total. Here, I obtained DC current and voltage values from a graph by right-clicking and copying the data. However, these data are sampled at a high frequency, with several data points per minute. It's impractical to manually copy and paste every minute's worth of data into Excel, especially considering that each minute contains at least 12 data points for both current (I) and voltage (V). I need to condense this data to one data point per minute to make it more manageable. Do you have any suggestions for a solution? regards, Regards, Nimesh
Yes problem still exist.
Hallo, Here it is. Simple Series_One MPPT.pvprj
Hallo, Yes, I did active recording of characteristics for modules via Options > Project Options > Simulation (1) After setting to All or MPP#. I am doing this same as you said since few days but it is showing me same message like do active recording of characteristic for modules which is active already. still it is not working in my pc. by the way thankyou for your help. regards, Nimesh
Hallo, As you said I try force simulation which did not work and also I made new whole system but I am not seeing I_V Curve in this system, I am not understanding what mistake I did. I am sharing you that file here. if can have a look and tell. Thankyou. Regards, Nimesh Simple Series.pvprj
This is really very helpful for me. Thankyour verymuch for your kind help. regards, Nimesh
Hallo Yield through orientation & inclination of the moduels surface is in Kwh/m2, normally it should be in degree or radian, why it is in kWh/m2 what does it means as you said in your another reply does it loss or gain ? Does all entity in excel sheet describe generation and losses in kWh as per your other response ? am I right? means the values which are in negative describes losses and values whoch are in positive describes generation. hope am i going right, actually i am new with this software. Thankyou verymuch for your time and reply. regards, Nimesh
Thankyou verymuch for your help, Mr. Frederik 1) I also have one another question, here I need one perticular day's I_V curve is it possible to get it? for example I need I_V or V_P (resulting curve) of one perticular day like 16 july, if it is possible, here I saw in PVsol. It saws ever minutes values chart which I do not want. Only one perticular day's genaration(I_V or V_P - resulting curve of day) on one graph I need. 2) Another thing is, I made few system for observation in all system it saws I_V curve option, but in one system which is simple design 5 module on east and 5 on west facing without shading< I am not able to see I_V curve I did change in setting and start recording of charachteristic curve option but still it is showing me only same message. does it requires something special to Highlights I_V Values? I am attaching SS. Thankyou verymuch for your time and reply. regards, Nimesh
Hallo, Deviation from the nominal module temperature kWh 1.01E-05 can someone explain what is this unit and what it trying to tell normally temp. unit should be in celcilus or in kelvin but here it is in kWh. Regards,
Hallo, I want to understand whole exported excel sheet of PV system, Is there any manual of any kind of detailed description of those all entity to understand? I am not getting almost ever entities are in Kwh/m2 which is so confusing for example, yield through orientation & inclination of the moduels surface in in Kwh/m2 with all values are in negative what it means? what those all values are trying to tell? Regards, 21_Nimesh
Hello, I have arrange 10 modules on west and 10 on east facing. here I want to connect 5 modules from east and 5 from west in series like that i wan to make 2 series array and want to connect those 2 series in one mppt and one inverter, is it possible to do connection like this ? and which inverter witn one mppt will help here? Second question is how can i creat shading on one perticular cell of module is there any way to hide or creat shadow on on perticular or specific cell of one pv module? could someone help for my this 2 question please. Thankyou, Regards, 21_Nimesh
