Umang
Umang's Achievements
  1. Hello PV*Sol Team, Recently I observed a change in data for PIKO inverters. In the manufacturer datasheet https://www.vpsolar.com/en/product/kostal-piko-ci-30-50-60-kw/ the max system voltage is 1100V for PIKO 60 but in PV Sol its limited to max MPP voltage (960V) which I think should not be correct. Can you please check and clarify if I am going wrong somewhere because 2months back I planned a project using this inverter and Solarwatt 405Wp modules, that time I could connect 24modules in a string but now its limited to 23modules due to this voltage limit change which would change the complete string planning. Also, would it be correct to connect modules in series that exceeds the max MPPT range but under the max system voltage as I understand that system will not always generate the max voltage all the time or there might be some issues later on. Could you please clarify?? Thank You. Umang
