Hello
I would be grateful if you help me understand clearly what the difference is between these types of operating inverters.
Type of operation: MPP1 , MPP2 ore
Type of operation: MPP 1+2
Thank you in advance,
Graniti
Hello Martin,
I selected to use inverter Tauro Eco 100-3-D and then from automatic configuration a have thate result.
From automatic configuration i have 2 inveters but inverter 1 is loaded with 112kW and the other one only with 88kW.
In this way MPPT of inveter 1 is overloaded.
Hello,
For a PV System with capacity 200 kwp i am using two inverters: Tauro eco 100-3-d
From softuer i have configuration :
Inverter 1: Tauro eco 100-3-d loaded with 112 kwp and
Inverter 2: Tauro eco 100-3-d loaded with 88 kwp.
What can i do in this situation to unload Inverter 1
Regards,
Graniti
Hello there,
I need help to learn how to select properly protection of PV systems and where is required (fuse, circuit breaker, isolator and overvoltage protection) using PVSOL.
Best regards,
Graniti
