glekaj
glekaj's Achievements
  • Dedicated Rare
  1. Hello I would be grateful if you help me understand clearly what the difference is between these types of operating inverters. Type of operation: MPP1 , MPP2 ore Type of operation: MPP 1+2 Thank you in advance, Graniti
  2. glekaj
    Inverter Selected
    I am using: Fronius International Tauro Eco 100-3-D
  3. glekaj
    Inverter Selected
    Hello Martin, I selected to use inverter Tauro Eco 100-3-D and then from automatic configuration a have thate result. From automatic configuration i have 2 inveters but inverter 1 is loaded with 112kW and the other one only with 88kW. In this way MPPT of inveter 1 is overloaded.
  4. Hello, For a PV System with capacity 200 kwp i am using two inverters: Tauro eco 100-3-d From softuer i have configuration : Inverter 1: Tauro eco 100-3-d loaded with 112 kwp and Inverter 2: Tauro eco 100-3-d loaded with 88 kwp. What can i do in this situation to unload Inverter 1 Regards, Graniti
  5. Hello there, I need help to learn how to select properly protection of PV systems and where is required (fuse, circuit breaker, isolator and overvoltage protection) using PVSOL. Best regards, Graniti
