Finn
Everything posted by Finn
  1. Hi fw, Thank you for your help. I found the setting. Best regards,
  2. Hi, How do you configurate the degradation of a module when using 3D mode for a solar project? I can see there is an option of enter the early degradation % in 2D, but I cant find the option in 3D. Is there an option I am not seeing somewhere? Or is it only possible to ender degradation in 2D mode? Best regards,
  3. Hi Martin, I understand the problem. Thanks for looking into it for me. I am not sure what value I should input for low light values. The module I was trying to create was the new Jolywood JW-HD144N / 570 W Can you suggest an appropriate value for this module? I have attached the sheet for the module. Best regards, JW-HD144N-550-575.pdf
  4. Hi Martin, I have send you my project as a private message. Thank you for taking your time looking at the project Best regards,
  5. Greetings, I am simulating a building with a large number of modules. The installed capacity is 4000 kWp and the simulated production is 9 760 000 kWh/year. This gives a performance ratio of 221,8 % This performance ratio is clearly not feasible. I have simulated the same project in Solysun and the simulated production is 2 700 000 kWh/year. PR is approximately 85 %. How do I fix this error to have a more feasible performance ratio for my project? Best regards,
