liszo
Everything posted by liszo
  1. Actually i'am using Agisoft Metashape Professional so i dont think its software problem.
  2. liszo
    3d import problem
    Hello Its again me I have problem with load 3d model into pvsol Its stopping at 97% and nothing more I'm sending .obj file so you can check it guys by yourself; https://we.tl/t-FKnS0fRuq7 That have around 250k verticles After all its loads up but my textures are missing; I did texturing in agisoft metashape and nothing...
  3. Hi, I was see the projects with textured walls on building in pvsol How to make project like this using only google earth image? Greetings!
  4. Sorry, I misspoke, my English is not very good. On Friday I started the project, saved it and didn't open it over the weekend. This morning (Monday) I come to work and want to finish the project. I opened it and everything was fine, so I got to work. After a few hours today I closed the modeling to check the yields, when I opened the modeling again to make minor adjustments, my whole project looks like the attached picture.
  5. You mean change of orientation? Yes, I did it and nothing happend If you're asking if that was the reason, then no, I didn't touch anything, everything was ok, I screwed up the inverter and the panels, I closed the whole project. I opened it again to make small corrections and this is what I found... I was doing a save every step because I haven't been working with this program since yesterday, but all versions of the saves are the same! This morning, when I opened the project for the first time since Friday, everything was fine.. This is what the project looked like this morning....
  6. I want help. https://we.tl/t-7GVAP9x28u adding my project as .pvj to make you check it by yourself
  7. Gentlemen, if your software is still in early alpha, please don't make me pay hundreds of dollars for it... I'm furious because I spent a few hours on the project in your refined program and after loading the file from the save I noticed this... It's very annoying that I had to create an account on your forum, otherwise I won't be able to work... Every time something goes wrong in your program...
  8. Hey, I'm a bit fed up with paying huge amounts of money for software that doesn't work properly and almost always makes my job harder... How can i repair my couple hours of work?
  9. Guys can i export a ready file with my 3d model ready panels on it into .obj file? Please let me know support Thanks you!
  10. I've solved a texture problem (i just forgot to build texture in agisoft) but i need help with modules... I cant put it on the roof, cause it comes under roof....
  11. Hello, I just made a 3d model, in agisoft, export it into blender, and finally i'm export it at .obj file and import into PvSol. After import, it looks like no textures (white building) this is my first problem. My secound is i can't put modules on the roof. What to do to prevent the modules from going under the roof? All on the screen.
  12. The blender did helped. Thanks.
  13. Hello, i haved used drone to make 3D model of building. All is good but after import the .obj file into pvsol my problem looks like on the photo; The building is crooked, i dont know what to do.. Help
