Tade
Everything posted by Tade
  1. I have the latest version of PV*Sol Premium installed. The problem with energy flows still persists!!! The program distributes energy flows as it wants!!! I bought the program as support for energy audit calculations. It worked perfectly with previous versions of the program. Now I can't use the paid program for more than two months! Will I be charged for the time the program is down? Optimalizácia byty a SP a TV 2025 - NEPOUŽÍVAŤ.pvprj
  2. Hello, PV*Sol Premium 2025 still has a lot of problems. This is what is happening to me now - when generating energy flows, it divides the energy in a senseless way - 22 MWh of PV production is divided into 22 MWh for direct consumption and 21 MW for the DHW storage. The exact same configuration in 2023 works correctly! ??? Námestie Biely Kríž 1-5.pvprj Námestie Biely Kríž 1 PVSol2025.pvprj
  3. Tade
    New license model
    Hi, I have been using a permanent license for years. This means that I can keep it and buy a new online version in 2025. Exactly for cases of work outside the Internet. I assume the new version will have no problem opening the file from the old version. Cool! Thank You!
  4. Tade
    New license model
    Hello, will it be possible to have the "old" model PV*Sol premium and the new one installed on the PC ? If I buy the full version of the new model (without the right to a discount when flipping the license), can I still keep the old version on the PC in case I work in a place without an Internet connection?
  5. Tade
    Battery choice
    Thanks for the detailed explanation. In the older version, it was possible to add the battery separately. Alright, according to your instructions, I can do it. Thank you again.
  6. Tade
    Battery choice
    Thanks, but that's the problem. I need to include a hybrid inverter and a battery in the system. If I configure a battery system with an inverter, as a result, the program will offer me two identical inverters. Why is it not possible to put only the battery itself in the system? After all, the batteries themselves are in a separate database. In older versions of the program, it was not a problem to add the battery itself. Or is there some "trick" for it?
  7. Tade
    Battery choice
    Why is there no choice of batteries in the PV*Sol Premium 2024 program? The dropdown is not active. There is only a battery system.
