Martijn
Everything posted by Martijn
  1. Dear, When i select the WALL function in: tab OBJECT VIEW then the 3rd icon WALL, then again 3rd icon WALL. I can drag this wall to my plane. but after that i want to adjust the orientation. right mouse click on the wall > EDIT > But there is no possibility to change the orientation. Only the coordinates are visible. Please give me advise how i change this orientation or solve this issue in the next update please. Thanks. Kind regards, M.Haaksema (Samenstromen)
  2. Hi Mikio, It's a pity that those details/ specifications (when 2 string DC connections is possible at one MPPT) is not incorporated in the PVsol software. But luckily a lot of other things do. Thanks for your reaction. Maybe in the future update this will be implemented. Kind regards, Martijn Haaksema
  3. Fronius GEN24 PLUS has 2x MPPT1 ports and 1x MPPT2 port, Why doesn't pvsol use this info? standaard configuration was 1 streng at mppt1 en 2 strengs at mppt2 , and pvsol says i have to use a T-combine plug. I changed this strand configurations to what Fronius suggests and still pvsols suggests this T-combiner at mppt1. why? because it is not necesarry to use it at mppt1: Please change this in pvsol for all inverters where this applies to.
  4. When i search with keyword 'BYD' in the selection list of battery's. there comes no option. when i search for 'gen24' from Fronius. then the HVM box of BYD is there. why not on keyword BYD? that would it be easier to find and to work with PVsol. but after goog looking. i sees it is the whole system of battery and inverter together what you can select, thats probably why BYD is not findable. its only an battery. Then you can better put above the search window 'INVERTER MANUFACTURER'
  5. Hello, I Have checked compatibility** from Enphase IQ-7A-72-2 with *SPR P3 385Wp panel. It says it is possible till 15A max. (Panels* are 10,63A Rated Current*** (Impp) & 11,3A Short-Circuit Current (Isc) (+/−3%). **https://www4.enphase.com/nl-nl/compatibiliteit-micros#results But in PV Sol after 10,2A it refuse to accept this combination. I know why this happen. Because the small letters from enphase datasheet: ""3. Maximum continuous input DC current is 10.2A."" Strange that Sunpower sells this combination with garranty.... how? And i cannot select this combination after copy this inverter and adjust limit settings in PV Sol from ***10,2A to 11A. First i thougt it was a fault in PV Sol. But now i see it is because the Enphase specs. I will contact them. Now PV sol will not suggests the Enphase micro inverter. Just someting to share. Where sometimes it gets stuck in work preparation. Regards, Martijn (OTG.energy)
      • 2
      • Thanks
