24 -
Everything posted by Johan
You can also add components (like batteries) yourselves. BR Johan
Hi Mikio, Thank you for the reply! With the CSV I can get something usefull, I was just hoping/wondering if it was possible to also add it to the customer report. Best regards, Johan
Is there any option to view the production forecast per day? Its easy to see per month the amount of kWh but it would be nice to have the option to see it per day.
I have not ever had that luck, in my cases if it was f*cked than better start all over.. Good that it worked out!
Hi Frederik, No I don't think he has rotated the building, this has happend to me also a lot of times (and it kills the humor for the day...). I have noted it tends to happen when you accidentely shift or move the "scetched mounting surface". I would also really wish that there is a good sollution for this issue! My trick now is to work slowly and save after almost every step if you have a roof with lots of surfaces you want to use. Keeping the 3D model and triangles within reason also seems to help. All in all you can notice that the core of the program is not really suited for these kinds of models... Greetz Johan
Hi Martin, Ha yes, now when I set it up (software wise) with 1 big string inverter (80kW) in the 3D enviromentand the in the "battery systems" 4x 20kW hybrid inverter it does seem to work. But it is strange that with this setup in PV*Sol you cannot create a correct simulation for a hybrid system. Will this be adjusted in future updates? Greetz Johan
As simple "ctrl Z" or undo button would be extremely nice! Greetz Johan
Hi Patrik I am using a DJI Mavic 2 enterprise and take a lot (>100) of overlapping pictures. Than I use WebODM to create a 3D model after that you need to clean up the model with Meshmixer for PV*Sol usage. For my purposes these 3D models arre sufficient. Greetz Johan
Indeed, this is a great question that I often have wondered as well. Or even better give the inverters possible custom names. Greetz Johan
Hi All, I have created a nice system, unfortunatly the customer is not allowed to feed into the grid. Now he has asked us to design a battery system to store the energy. Unfortunatly or I am doing something wrong or I encounter a bug... The problem is that with or without batteries there own usage part remains exactly the same. What I can see in the results is that on a sunny day also the betteries are not being charged. Can someone see if I am making a F*up ? Greetz Johan
Hi All, After designing a nice system PV*Sol keeps crashing when determining shadows. Any ideas how to solve this? Greetz Johan
Hi Martin, I have tried to use a smaller size, this did not change the result. Currently I am using 16Gb of RAM, now I will upgrade to 64Gb also for some other aplications a bit more than 16Gb could be usefull. The other specs should be more than sufficient I think: CPU - Intel Core i9-9880H Storage 1TB SSD NVIDIA GeForce RTX 2060 What is the amount of RAM used by you're colleagues? Greetz Johan
Bump.... @developer_mh is there anything you can tell me? I have send the requested email, but until now I have not received any reaction regarding this issue. It would be great if we could get a reply Greetz Johan
Hi Larissa, It's best to ask the questions in English, but I think I can understand you're question. If you right click the model and choose edit you can set it for "Tilt backwards" Than it should be in the correct alignment. Greetz Johan
Hi Jummy, I have send you the download link for the files in a DM. It would be great if you could have a look! (It would also be great if Valentin could have a look). Greetz Johan
Hi Martin, Did you or you're collegues get my email? A support reply would be highly apreciated! Greetz Johan
Yes it would be great to be able to load the .IFC files! We very often use these files and than extract drawings to be able to make a 3D model again.
5- a option to store the texture of the PV modules 6- a option to save a standard construction for flat roof
Hi Jimmy, For this model I only have 49 texture images, so I am guessing that that should not be the issue.
Unfortunatly changing the file names did not work for me. I have send a email to the requested email adres, once solved I will reply here to possibly help other people.
Hi All, I am having quite some issues with the importing of 3D models. Very often (if not always) there are white spots / there is texture missing. When I open the 3D file wich is a .OBJ file with a 3D viewer it looks fine, after importing it to PV*Sol premium 2022 R2 there is texture missing. Sometime after restarting the program it becomes a bit better but not always. Can someone give me some tips on how to prevent this? Greetz Johan
My wish list would be as follow: 1- a CTRL-Z or Undo function would be very handy as this is often missed 2- we make quite a view calculation for the same customers, so a (private) database for these customers would save a lot of time. 3- a more useable 3D model import would be great, import ability from .IFC file would be excelent because they are being used a lot in construction work. 4- the option to set the "outline" to a different colour is very handy especially if you are working from a drawing
