Johan
Johan last won the day on January 9 2025
Johan had the most liked content!
1 Follower
Contact Methods
  • Website URL
    www.bouwkeurgroep.nl
Profile Information
  • Gender
    Male
  • Location
    The Netherlands
Johan's Achievements
Explorer
Explorer (4/14)
  1. Johan
    Add battery
    You can also add components (like batteries) yourselves. BR Johan
  2. Hi Mikio, Thank you for the reply! With the CSV I can get something usefull, I was just hoping/wondering if it was possible to also add it to the customer report. Best regards, Johan
  3. Is there any option to view the production forecast per day? Its easy to see per month the amount of kWh but it would be nice to have the option to see it per day.
  4. I have not ever had that luck, in my cases if it was f*cked than better start all over.. Good that it worked out!
  5. Hi Frederik, No I don't think he has rotated the building, this has happend to me also a lot of times (and it kills the humor for the day...). I have noted it tends to happen when you accidentely shift or move the "scetched mounting surface". I would also really wish that there is a good sollution for this issue! My trick now is to work slowly and save after almost every step if you have a roof with lots of surfaces you want to use. Keeping the 3D model and triangles within reason also seems to help. All in all you can notice that the core of the program is not really suited for these kinds of models... Greetz Johan
  6. Hi Martin, Ha yes, now when I set it up (software wise) with 1 big string inverter (80kW) in the 3D enviromentand the in the "battery systems" 4x 20kW hybrid inverter it does seem to work. But it is strange that with this setup in PV*Sol you cannot create a correct simulation for a hybrid system. Will this be adjusted in future updates? Greetz Johan
  7. Johan
    PV*SOL Wishlist
    As simple "ctrl Z" or undo button would be extremely nice! Greetz Johan
  8. Hi Patrik I am using a DJI Mavic 2 enterprise and take a lot (>100) of overlapping pictures. Than I use WebODM to create a 3D model after that you need to clean up the model with Meshmixer for PV*Sol usage. For my purposes these 3D models arre sufficient. Greetz Johan
  9. Indeed, this is a great question that I often have wondered as well. Or even better give the inverters possible custom names. Greetz Johan
  10. Additionally also the heatmap does not show any charging
  11. Hi All, I have created a nice system, unfortunatly the customer is not allowed to feed into the grid. Now he has asked us to design a battery system to store the energy. Unfortunatly or I am doing something wrong or I encounter a bug... The problem is that with or without batteries there own usage part remains exactly the same. What I can see in the results is that on a sunny day also the betteries are not being charged. Can someone see if I am making a F*up ? Greetz Johan
  12. Hi All, After designing a nice system PV*Sol keeps crashing when determining shadows. Any ideas how to solve this? Greetz Johan
  13. Hi Martin, I have tried to use a smaller size, this did not change the result. Currently I am using 16Gb of RAM, now I will upgrade to 64Gb also for some other aplications a bit more than 16Gb could be usefull. The other specs should be more than sufficient I think: CPU - Intel Core i9-9880H Storage 1TB SSD NVIDIA GeForce RTX 2060 What is the amount of RAM used by you're colleagues? Greetz Johan
  14. Bump.... @developer_mh is there anything you can tell me? I have send the requested email, but until now I have not received any reaction regarding this issue. It would be great if we could get a reply Greetz Johan
  15. Hi Larissa, It's best to ask the questions in English, but I think I can understand you're question. If you right click the model and choose edit you can set it for "Tilt backwards" Than it should be in the correct alignment. Greetz Johan
