Zhaoyu
Zhaoyu's Achievements
  1. Hi, I am building up a PV system with Solaredge inverter and Solaredge Power optimizer, I checked the products datasheet the configuration should be OK, however, there is a notification:"No system check possible,Please use the Solaredge site designer for checking", which causes I can not selected 'OK' and go ahead. How can I fix the problem or skip the ’system check‘?
  2. Hi , I would like to know the AC output of the system,but the values could not be found in the simulation hourly values results(excel file). What I did right now is that I used the Grid feed-in energy as the hourly AC output of the inverters, however the values are much lower than the nominal power of inverters which is unreasonable.
  3. Problem solved,Thnx Martin!
  4. Hi, I am using PV*SOL Premium 2021(R7) and MeteoSyn 5.0.30.0. and trying to import measured data to PVSOL, and MeteoSyn giving the error message of "Missing information could not be imported." I checked the Internet which is normal, also different proxy settings have been tried, still got the same error message. My .dat file is attached as follow. I would appreciate your help. Thank you! 11110-11(test4).dat
