AljazG
Everything posted by AljazG
  1. Dear all, I have a question regarding the definition of cable losses on DC and AC side. In the TAB "cables", if I press "in detail" cable loss function I would like to define separate for each inverter the AC and DC cable length in order to calculate losses. What I just saw, that if I define 16 x the same inverter, with same string configuration and 1 x same inverter but other string configuration, the software shows on the left side only two cable configurations (see picture bellow). If I want to define exact cable length of each inverter of those 16 (which are not on the same position in the PV installation), I need to define separate for each inverter the length of AC cables from meter to inverter and be able to define all DC topology per MPP tracker. In your case the program defines the same configuration and input for all 16 inverters and allows only define other inverter with other cable lengths. I also don't see the definition of Transformer loss, since I can add it as a symbol on the cables tab. I also tried to define each of 16 inverters separately (not as 16 x Inverter), but didnt work. Can you please advise me, if I can define each inverter cables separately and how and how to define the transformer loss? Thank you in advance, Aljaz
  2. AljazG
    Large PV Farms
    Dear all, I have a question, if there is any possibility to simulate large PV Farms bigger then 7500 or 10000 PV panels? Thank you. Aljaz
