Hello i am making a simulation with with a hybrid inverter battery system . The hybrid inverter i am using is SMILE T-10 from Alpha ESS . When I make the inverter configuration i am also supposed to specify the same as the battery system where as the inverter is supposed to act as a battery system since it is hybrid. When i chose the battery system i have to opt for 4 of hese bateries, where as ideally its just supposed to be one whole unit for a battery and an inverter.
any help would be appreciated.
athnkyou
Yash Bhosale
Yes that seems weird. I rectified my coordinates, and they are for a location in vienna.
I would eagerly await for your solution over this ( if it is possible to debug).
Thanks for your help so far.
Kind regards,
Yash Bhosale
I am sorry but the location after importing doesn't appear in the list. Is there a different way to access it?
Once again thank you for the assistance so far
Thanks a lot, this worked for me.
The file is added now.
I just have a last query. Now since this newly created file is added in meteosyn, do i have to additionally now change the location or the program will assume this climate data for my simulation?
Hello dear developers,
I want to add my climate data for which i have exactly made the .dat file according ro the given format by PV*SOL. But the moment i add the data, it says Conversion failed.
I would sincerely look forward for some help
kefergasse.dat
