Sondre207
28 -
Everything posted by Sondre207
Hi, On the length of the DC-cable, what does 2x Go-and-return means? Does the cables between panels count? And is it the length as cable 1 in my drawing, or 1+2?
Thanks for answering!
Hi, Is it possible to add in my dimensions here? That means, choosing the distance that I want it too show? For example, I would like to know the distance shown in the green line.
Hi, I have trouble finding sunstyle (manufacturer - pvmodules) in the list. A friend of mine sent me this screenshot, showing that she has it in her list. Is there any reason that I do not have it? When I check for updates I get this message: Thanks in advance!
Thank you
Hi, I created new meterological data for Fagernes, which gave me quite a big difference from the one before (see images). I see that the one I created is from Meteonorm 8.1 and the old one is from 7.2. Could it be correct that the value is this much higher or is it something that happens in the interpolation process?
Haha, nice! I understand
Hi, I have problems when adding consumption data. I add in 12,9% for february and 12,67% for march and everything looks ok. But it still looks like consumption is higher in march. Any tips for what I should be checking?
Hello, I have added solar tiles to a sketched mounting surface. They are the colour black, and will be surrounded by tiles or different materials. Is there any way I could change the texture of the surface to something different so it would look more esthetical nice? (see image) Thanks for all the help
Awesome Jimmy! Thank you very much Have a nice day!
Hi, Is there any way that I can get the string number to match the red line below? When I choose different sorting options, it seems like it is not possible? Could I choose them manually for example? Thanks in advance!
Thank you very much!
Hello, I want to use the horizon in PVGIS (see image), as there is no method of getting that in PVSOL...? I was wondering if there was any way to convert .csv or .json -files to .hor that is used in PVSOL? Thank you in advance, your help is much appreciated
Hi again Frederik, Hope you are still here In a way, what we did last time, works. The only problem is that when you install these panels to the roof, they are installed laying on top of eachother (see image). This is taken from the software tool of the sunstyle-manufactor. That means that the area is no longer 870x870, but a little less. I have tried to work out some solutions, but none that has worked so far. I understand I am asking a lot here, but do you have any suggestions? Have a nice day!
Hi, I was wondering, the simplified circuit diagram under PV-system in the report is often empty (see image). This is even though the circuit diagram in the "plans and parts"-section is correct. How can i make it show under the PV-system?
Hi, I have a question regarding imported models in PVsol (see image). Because it is drawn with the correct elevation over the sea, it is floating in the air in the pvsol software. In my opinion, this should not affect the simulation, if anything it will make it even more correct. What is your opinion?
Hi Martin, Happy new year to you as well Thanks a lot for the answer, that helps! Have a nice day
Awesome Frederik, thanks! Have a great Christmas - holiday!
Hi again Frederik, Thanks a lot for the answer to my question! I will try this. This is not possible to do in the 3D-configuration, or?
Hi, Thanks a lot for the answer in advance, it is much appreciated. I was wondering about the financial analysis; I have added in the program that the elecricity price is 1kr/kWh: In my head the "Total Payment from Utility" and PV Generator Energy (AC-grid) should be the same. What is the reason for the difference?
Hi Frederik, I was wondering if you had seen my question
