and
Everything posted by and
  1. Hi Martin again. I would like to ask your help regarding a couple of graphic issues that i face when i try to export the report First in the cable plan i get this form. Is there a way to make it larger and make it fit better in the page? And second when i want to get the string configuration the resulting image is not very good in terms of resolution so the cable lines are not clear enough. Is there a way to either change the weight of the line or improve the resolution? I also tried printing them on A3 but still no much improvement. Thank you
  2. Thank you Martin, this fixed the issue.
  3. Hello PV*SOL community. Either i am missing something (despite my search) or this feature is not available. Let me explain: I have two adjacent roofs and i want to use some modules from the one to fill up the capacity of the inverter i use in the other (one installation is bigger than the other and i am allowed to use just 3 specific inverter models). When i try to group them together PV*SOL fails to suggest a suitable configuration so i go for the manual polystring configuration. But this feature (poly-string) works only with one inverter model for all the group (group = the two roofs together) and does not let me choose two different inverters in order to distribute my strings manually. Am i missing something or such cases cannot be designed with PV*SOL ?
