Hi Martin,
Many thanks for your answer and the link to the help site, this helps in starting to understand the calculations and PR predictions from PV*SOL. Some additional questions for better understanding:
Could you explain how "Module-independent shading is not accounted in the calculation of the PR", as you use the "Global Radiation at the Module" for the PR calculation, and for determining the "Global Radiation at the Module" from "Global Radiation - horizontal" you use "Module-independent shading" as well?
When we use a 3D model as input with regular rows of modules where the diffuse shading factor for the inner modules is higher due to the shading by the row in front, will also then the value of the first row be selected for all modules? if yes, are 3D models than only for shadow calculations from buildings, vergitation, cooling installations, etc. relatively nearby?
Next, on the help site I found out that you are determining a heat loss rate UA. (where) is that included in the PR calculations?
Thanks in advance
