Gorka
Everything posted by Gorka
  1. CUAL ES EL MEJOR MODELO DE IRRADIACIÓN DIFUSA PARA UTILIZAR EN PROYECTOS EN ESPAÑA? QUIERO QUE LA GENERACIÓN QUE CALCULA EL PVSOL SEA LA MAS CERCANA A LA QUE CALCULA EL PVGIS.
  2. Hola, ¿ Como puedo configurar un proyecto con baterías que carguen de la red?
  3. EN ESPAÑA HAY TRES TIPOS DE INSTALACIONES SEGUN EL DECRETO 244/2019. AUTOCONSUMO SIN EXCEDENTES, AUTOCONSUMO CON EXCEDENTES ACOGIDOS A COMPENSACIÓN Y AUTOCONSUMO CON EXCEDENTES NO AGOGIDOS A COMPENSACIÓN (VENTA A RED A PRECIO "POOL". MI CONSULTA ES PARA LA PRIMERA PREGUNTA, COMO PUEDO HACER QUE EN PVSOL NO VIERTA LOS EXCEDENTES A LA RED PARA QUE NO LOS CUENTE COMO BENEFICIO EN EL ESTUDIO ECONOMICO DEL INFORME. Y QUE EN LA GRAFICA NO APAREZCA LA ENERGIA VERTIDA A LA RED, YA QUE POR NORMATIVA HAY QUE INSTALAR UN SISTEMA DE ANTI-VERTIDO PARA ASEGURAR EL NO VERTIDO A LA RED DE LA ENERGIA EXCEDENTE. Y RESPECTO A LA ÚLTIMA PREGUNTA ES SABER SI SE VA ACTUALIZAR LA NORMATIVA QUE APARECE EN ESPAÑA QUE ES MUY ANTICUADA (2008). GRACIAS.
  4. HOLA, COMO SE PODRÍA CREAR UNA INSTALACIÓN SIN EXCEDENTES CON UN SISTEMA ANTI-VERTIDO (WATIMETRO: JANIZZA, DTSU666-H 250A/50mA(HUAWEI)...)? PARA CUANDO SE ACTUALIZARÁ LA BASE DE DATOS METEOROLOGICOS PARA ESPAÑA? Y LA NORMATIVA Y REALES DECRETOS (AÑO 2008) CUANDO SE ACTUALIZARAN? GRACIAS, UN SALUDO
  5. Gorka
    trees
    Why can I only enter 50 trees? Is there any way to introduce more trees? Thanks and greetings to the PVSOLERS
  6. The photovoltaic solar installation that I must design is located in different buildings, which are separated from each other. These buildings are located in a valley, that is, surrounded by mountains except the south. After calculating with an inclinometer in the place and noting the angles of height of the horizon, I have introduced them in the pvsol. But when calculating the shadows does not take into account the horizon, what should I do to take into account that horizon that I have manually introduced? Thanks and greetings to all who are PVSOLERS, hehe pd: Great photovoltaic design program, to say the best.
